lifters reusable?
Old Dec 28, 2001 | 11:40 PM
smokin87iroc's Avatar
Car: 87 IROC
Engine: 305 TPI going to LT1
Transmission: 5spd
lifters reusable?
ok i'm getting a good deal on a lt1 valvetrain. everything but the lifters.
question is, can i reuse my lifters on the lt1 cam? i do have roller lifters but they have 120k miles on them. i thought roller lifters didn't wear like flat lifters do but i want to know from someone that knows.
thanks everyone and if you need more info just ask
Andrew
Old Dec 29, 2001 | 04:18 AM
rezinn's Avatar
You can reuse stock roller lifters.
Old Dec 29, 2001 | 12:04 PM
Guest
Guest
Posts: n/a
Yea, you can reuse the old ones. Just check them out and make sure they arent screwed up, like the roller should be flat with minimal grooves and pitting, and the roller should turn/spin nicely.
Old Dec 29, 2001 | 01:56 PM
Car: 87 IROC
Transmission: 5spd
thanks for the help guys.
i'll just check them and see
Andrew
Old Dec 29, 2001 | 02:09 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I alwasy like to make sure that the lifters go back into the same hole they came out of. Some get there own wear pattern.
tyeo098
Nov 30, 2015 06:27 PM
codeysabatini
Nov 10, 2015 04:07 PM
skinny z
Oct 5, 2015 06:23 PM
TX-SleeperC5
Sep 24, 2015 03:13 PM
dimented24x7
Sep 6, 2015 03:51 PM
