Need a dimension please
Can someone with factory TPI/700R4 please pull a dimension for me? Basically the throttle cable bracket in relation to the throttle arm. See attached picture.
Much appreciated!
Much appreciated!
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Need a dimension please
4 7/8 from the tv bracket front to the center of the tb tv stud.
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Question:
Does it matter what model year the throttle body is? I know late model throttle bodies are different in some respects than early models. Did the change effect the linkage arm as well?
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Get the spring dohickey from Sonnax to allow setting it correctly.
Mine likes a bit of tension right off idle but then is over pulled at WOT.
http://www.sonnax.com/parts/2765-tv-cable-corrector-kit
