TPI Intake Manifold on 1992 Z28 G92
Car: 1992 Z28 G92
Engine: 350-245 (B2L)
Transmission: ?
Axle/Gears: G80
Good morning everyone, I have been scouring the internet for a solution to a problem. Finally gonna try here.
I have a 1992 Camaro Z28 G92 that needs a replacement TPI Intake manifold, my mechanic tells me that the engine has cast iron heads. I believe the original intake was aluminum.
My question is, how do I identify the proper replacement part? I'm told the casting number on the intake will clarify the issue, but I don't have this info available to me at the moment.
I really hope someone can help me here, it is very hard to coordinate car repairs while deployed overseas. Thank you guys in advance for your help.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: TPI Intake Manifold on 1992 Z28 G92
Casting number 10088016 . Or Iirc 10088015 87-88 Tpi f body base will work.
Vettes used the earlier mounting holes for the center four holes and a coolant crossover.
