tpi oil pressure problem
Old Jan 2, 2017 | 10:19 AM
billy89's Avatar
hey guys, need some help with an 89 5.7 t.p.i motor that was swapped into a monte ss. the motor is blowing the seal on the oil filter when i start the engine. as much as 2 quarts shoots out in just a few seconds. i replaced the filter adapter that was cracked in half thinking this was the problem but i still have the same issue. i tried 3 different brands of filters all with the same results.the motor was sitting for a long time before i got it running again, it runs well except for the oil leak issue. the motor is stock and original with low mileage.the motor does not have an oil cooler on the block. if the cause is a stuck pressure relief valve inside the oil pump causing a spike in pressure would i have to pull the motor and change the pump. i read stories about clogged oil passages being cleaned out by running a mix of 50w with a quart of atf. thanks for any advise.
Old Jan 2, 2017 | 12:11 PM
greenyone's Avatar
Car: 91 G92 Z28
Axle/Gears: 342
Re: tpi oil pressure problem
You can try the atf trick. Maybe run it for 20 minutes and drain. Are you sure you don't have a doubled up gasket? If none of that works it sounds like you're going to have to drop the pan and replace that pump. Not sure if that is doable in a G body without pulling the motor. It can be done on the thirdgens, but you have to get the motor up 3-4 inches which usually requires unbolting the motor, trans crossmember, dizzy, starter, exhaust, blah blah blah etc...
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Sounds like you need to replace the pump. Melling 55 pumps are so cheap I wouldn't even waste time cleaning the pump relief.
Old Jan 2, 2017 | 01:13 PM
billy89's Avatar
trying to avoid pulling the motor in my driveway going into the winter.not sure i would be able to run the motor for any period of time with the way the oil is shooting out. no doubled up gasket that was the first thing i looked for. thanks guys
Old Jan 4, 2017 | 07:07 PM
rongreen's Avatar
Car: 1938 Chevy 2 dr Sedan
Engine: Dart400 AFR190 TPIS ZZ409 Big Mouth
Transmission: Gearstar 700R4 level 4
Axle/Gears: Moser 12bolt-Det Trac loc 3:42
Try rotating the oil filter adapter 180 degrees, that took care of the problem for me after installing a new short block. The oil ports in the block and adapter are most likely misaligned creating a restriction to oil flow and lot of back pressure. If you a have spare stock block compare the two adapter orientations. Be sure and careful needless to say do not blow up your engine trouble shooting the problem. I hope this helps you.
Old Jan 6, 2017 | 09:43 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Stupid question, but you're running an oil filter adapter with a bypass valve, yes?
Old Jan 6, 2017 | 11:25 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
I'd bet the new adapter is cracked as well.
Old Jan 15, 2017 | 01:16 PM
rongreen's Avatar
Did you find the the cause of the problem?
Old Jan 16, 2017 | 09:03 PM
rongreen's Avatar
Fix it yet?
