How much power should i get from these mods????
Old Dec 30, 2001 | 01:03 PM
redtail2426's Avatar
I have a 305 tpi in my 88 transam and i have 1500 to spend on mods.I was thinking of doing slp 1 5/8 headers,high flow cat,ignition coil and distributor upgrade,wires,new plugs,edelbrock high flow base with slp intake runners,porting the stock plenum,adjustable fuel pressure regulator.I already have a flowmaster catback.Let me know how much power u think i should gain from these mods.thanks.
Old Dec 30, 2001 | 06:15 PM
Eighty5TransAm's Avatar
I found that I didnt get much help from modifying the TPI on my 305, exspecialy for the price of those parts.
Old Dec 30, 2001 | 06:52 PM
jasman19's Avatar
Car: RED 1986 IROC-Z28
Engine: 350 5.7L
Transmission: TH 700R4
Axle/Gears: 3.23 10 Bolt
with that much money you could go through jim pace and get a new 350. Or maybe save another grand and buy a 350 ho with 350 hp?? But I think the major thing that you could do to that 305 is heads and a cam. Then go and get a gear for the rear end.
Old Dec 30, 2001 | 09:43 PM
Don_89Iroc's Avatar
i agree i think you should get the headers maybe, but try a cam and better heads you could get a good set of heads and a good cam for around 1500$
Old Dec 31, 2001 | 08:35 AM
GRENDLE's Avatar
i agree with the heads and cam. for just over a grand you can get trick flows, and a good cam. that would do more than the rest of the mods combined. use the rest for a die cutter set up (porting tool) either air or electric. and you can make more wile having fun grinding. or you can probably find a good rebuilt motor (350) for $1500 , or i've seen used LT1's and LS1's going in that range. lots to choose from when you have a lump sum.
jhawkeye
May 25, 2022 06:33 PM
haps
Interior Parts Wanted
Sep 8, 2015 10:15 AM
Warlocksirix
Aug 29, 2015 11:36 AM
Chuck84TA
Aug 27, 2015 11:14 AM
sailtexas186548
Aug 24, 2015 10:11 PM
