C4 L98 EGR vs. F-body EGR
Old Feb 13, 2017 | 07:34 PM
yaj15's Avatar
Car: 1988 IROC-Z
Engine: L98 - full intake & exhaust boltons
Transmission: Bowtie 700r4, 2400 rpm stall
Axle/Gears: Borg-Warner 9bolt, 3.45 gears, posi
What is the difference between the f-body EGR and the C4 EGR set up?
I've the chance to buy a low mile C4 L98 but since I live in California I have to smog the car. The smog guy might call out an external EGR.
Old Feb 13, 2017 | 07:38 PM
thtanner's Avatar
Car: 1989 Pontiac Formula 350
Axle/Gears: BorgWarner 3.27 Posi
Re: C4 L98 EGR vs. F-body EGR
Hard to say, depends on the smog tech. All smog equipment will be present in the stock locations, just the EGR tubing is external on the vette I think. I'm not sure the reference they use will get that specific?
Old Feb 13, 2017 | 07:44 PM
yaj15's Avatar
Car: 1988 IROC-Z
I sure hope not. Other than that it's a direct swap. All the f-body parts should just bolt up.
Old Feb 14, 2017 | 09:48 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
If you have headers you might want to contact dyno don or scoggin dickey and see if they still make sd3816. Sd3816 use to be the pictured kit now the vortec intake on.
Old Feb 14, 2017 | 10:19 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Old Feb 14, 2017 | 10:37 AM
yaj15's Avatar
Car: 1988 IROC-Z
Thanks Tuned. I'll contact them and see if they still make this kit.
Old Feb 14, 2017 | 10:51 AM
Engine: Lb9
Transmission: M20
If you can't find one you can always cut the piece off a vette manifold. I think I have the pieces as well .
Old Mar 24, 2017 | 04:38 PM
yaj15's Avatar
Car: 1988 IROC-Z
Would I be able to pass smog if I got rid of the EGR system?
I could leave it in place to pass the visual and have it tuned out of the computer. Would that make the NOx emissions to high to pass?
Old Sep 28, 2019 | 01:38 PM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Is Kevin still doing tunes? May wind up with a TPI car this yr
Old Sep 28, 2019 | 01:56 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Yes he is
SD disco'd that part
Old Sep 28, 2019 | 01:58 PM
Dyno Don's Avatar
That might work with aluminum heads, have done a few.
Old Sep 28, 2019 | 02:00 PM
yaj15's Avatar
Car: 1988 IROC-Z
Sounds good. I'd need to do that if I bought a zz6 crate motor
