305 Heads
Car: 89 Camaro RS
Transmission: 5 Speed
305 Heads
I have a 305 with TBI heads now with a TPI installed. I found a set of 416 305 ho heads rebuilt for 100. Would I see much power gain swapping to these heads? I'm currently running a LT1 cam also. Thanks
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 305 Heads
The 416 flow better than tbi heads, just a guess they maybe worth 30hp at the flywheel.
You can run a Corvette TPI intake manifold or elongate the center four holes of the intake unless your using a 85 manifold.
Car: 1983 G20 Chevy
Transmission: 4L60
Re: 305 Heads
You will see very little in the way of HP gains even if you port the 416s. I would suspect less than 25 hp @ 5,500 rpm. You will see a power loss clear through 4,500 rpm.
