New Car Craft Article on 305 TPI vs. Ford 5.0.
Old Mar 24, 2017 | 02:12 AM
Nelz's Avatar
It's a pretty interesting read. Can't wait to see what they do.
http://www.hotrod.com/articles/302-f...2&sf65442022=1
Old Mar 24, 2017 | 06:16 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: New Car Craft Article on 305 TPI vs. Ford 5.0.
I just read that, very interesting, I noticed it has the LT1 t-body on it (not that it matters)wonder which cam was in the TPI? Really kind of shows how bad the stock exhaust and chassis weight hurt the F-platform (vs fox chassis) .
Old Mar 24, 2017 | 12:15 PM
Drew's Avatar
Don't forget the popularity of the T5 in the mustang, and 2.77 gears in thirdgens. Not that all Fox Mustangs got good gears, but Ford Motorsports gears have a reputation for frequently dropping in with the existing shims.
Old Mar 25, 2017 | 04:00 PM
GCrites80s's Avatar
Car: '87 IROC-Z
Engine: TPI 5.7
It won't be a real car magazine story until the turbos get put on.
Old Apr 14, 2017 | 05:28 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
This will be a fun article. It is pretty amazing how bad the stock manifolds and factory T-pipe are. Not sure what GM was thinking there.
Old Apr 14, 2017 | 10:15 PM
TTOP350's Avatar
Can't be faster than a corvette
Old Apr 15, 2017 | 07:49 AM
PurelyPMD's Avatar
Car: 1987 IROC Original Owner
Engine: LB9
Transmission: M39 MM5
Axle/Gears: G80 G92 J65
Bingo!
You also need to remember this was a period in our lives (one of many) when people were trying to restrict our rights - remember Tipper Gore putting warning labels on albums?
Old Apr 15, 2017 | 08:43 AM
Drew's Avatar
I think you can blame it on packaging and necessity just as easily. For the smogger era they were designed, the manifolds were adequate, and the T probably saved couch cushion change on every assembly welded together vs a true Y pipe.
Old Apr 15, 2017 | 12:48 PM
craze's Avatar
Car: 87 TA (presently a roller)
Engine: TPI 350 (...on an engine stand)
Transmission: 700r4 (bailing wire'd into the car)
Axle/Gears: factory 2.73 posi 10 bolt
For all their problems in their stock applications(the time period in which these motors had their heyday obviously having a significant influence on the matter), I'm still excited to see where they go with this article in parts 2 and beyond... Could be fun!
Old Apr 15, 2017 | 01:50 PM
LiquidBlue's Avatar
Car: 90 Formula / T-tops
Transmission: MD8
Fun article, keeps us posted when it updates. Subscribed!
Old Apr 15, 2017 | 07:09 PM
NoEmissions84TA's Avatar
The 302 Ford combined a 4.0-inch bore with a 3.0-inch stroke. This compares to a 3.736-inch bore and longer 3.48-inch stroke for the 305.
If they wanted to do a true comparison, then they should test the 302 Ford against a 302 Chevy (4.0-inch bore with a 3.0-inch stroke). YES, Chevy also made a 302. 1967-1969.
Old Apr 17, 2017 | 05:14 PM
FormulaL98's Avatar
Car: 88 Formula, 72 Nova, 68 Chevelle
Engine: L98, mild 350, L79 327
Transmission: 700R4, M20, M20
Axle/Gears: 9b 327,10b 373, 12b 331
Having owned both a pair of 5.0 fox's and my Firebird, car for car the third gens where way ahead. Far better car to drive. The 5.0s where cool, ford definitely employed some old hot rod tricks to what they had at the time. The factory 5.0 headers where nothing to write home about, but literally anything GM could have come up with other than the log style manifold would have been an improvement. The switch to a set of Dyno Dons was without doubt the best mod I ever made.
I did bang shift a bolt on only 89 5.0 to 13.12@103, they are fun and all the speed parts can be had on craigslist now.
Old Dec 6, 2017 | 02:51 PM
Nelz's Avatar
370hp 305 tpi. Not bad.
http://www.hotrod.com/articles/5-0-fistfight-pt-2/
