Engine won't stay running
Old Mar 27, 2017 | 07:20 PM
RonB1979's Avatar
Car: '89 Camaro RS convertible
Engine: 5.7 TPI
Axle/Gears: 4.10
I have a built '89 355 TPI full roller, edelbrock heads, high flow runners and intake. It starts up but runs at a high rpm for about 30 seconds then shuts off. Checked for vacuum leaks and didn't find any. Even if it is a vacuum leak it shouldn't just shut off.
Old Mar 27, 2017 | 07:40 PM
TylerSteez's Avatar
Car: 86 Trans Am WS6
Engine: 383 stroker
Re: Engine won't stay running
are you running it on the stock prom?
Old Mar 28, 2017 | 12:34 AM
truckguy's Avatar
what about fuel and spark or timing?
Old Mar 28, 2017 | 01:14 AM
RonB1979's Avatar
Engine: 5.7 TPI
Axle/Gears: 4.10
I have a stock one and a couple custom tuned ones. Also have the one that was in the car the engine came out of but that one is setup for manual and mines an automatic
Old Mar 28, 2017 | 01:20 AM
RonB1979's Avatar
Engine: 5.7 TPI
Axle/Gears: 4.10
Checked all of that. It runs at about 2800 rpm for about 20 seconds at the most then shuts off. Thinking maybe vats. Someone said The fuel pressure circuit runs threw the oil pressure sender and if thats bad it may do that.
Old Mar 29, 2017 | 03:54 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
With the idle that high it has to be a vacuum leak or possibly low fuel pressure.
