Engine block numbers
Old Apr 2, 2017 | 01:26 PM
Gangsta Stude's Avatar
Car: 1940 Studebaker Commander
Engine: TPI 350
I was told I would find identifying numbers on this tab. I don't see any numbers, is this the right location?
Old Apr 2, 2017 | 04:09 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Engine block numbers
Looks like a target master engine, go bye the casting number on the block behind the drivers side cylinder head.
Old Apr 2, 2017 | 08:57 PM
Engine: TPI 350
It looks like it's 140S379. What's a target master engine?
Old Apr 3, 2017 | 11:57 AM
Engine: Lb9
Transmission: M20
14016379 maybe 67-80 350 left hand side dipstick. A target master was a gm replacement engine. The suffix code would be missing not assigned to a vehicle vin number.
http://www.jimsperformance.com/blocks.html
Old Apr 5, 2017 | 07:33 AM
Engine: TPI 350
Thank you. I did a little more digging and found you were right about the number. I also found another link that explains the numbers. Looks like it is a 77-79 motor with either 2 or 4 bolt mains. All the suspension in the car
is from a camaro so I'm guessing the entire drivetrain was sourced from a camaro of those years.
