New fuel pump, can't get started
Car: 89 IROC Z
Engine: 5.0 HO TPI
Axle/Gears: 2.73 Posi
I have an 89 IROC, 305 TPI. Car had been sitting for a couple years before I bought it with a bad fuel pump. I've recently replaced the fuel tank, pump, and filter. Since then, I haven't been able to get it started. I've got fuel to the fuel rail, tested each injector harness with a noid light with positive results, and can run the engine on starting fluid but once it burned off, no dice. So, question is, bad injectors or something else?
thanks,
Ed
thanks,
Ed
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: New fuel pump, can't get started
If it's been sitting for years the injectors are more than likely varnished and stuck.
https://www.southbayfuelinjectors.co...el-injectors-8
Did you put new gas in the tank, or is it old gas? ....I'd probably flush the lines out too, if it's been that long. New filter....everything.
Car: 89 IROC Z
Engine: 5.0 HO TPI
New gas, 100% 93 octane, and new fuel filter. I also let as much of the old gas drain out of the line when I took the old filter off.
Well even bone stock from the factory, the injectors weren't great. Definitely recommend replacing them as Tuned Performance recommends. MANY of us here have had good experience dealing with SouthBay.
Car: 89 IROC Z
Engine: 5.0 HO TPI
Once I get my check from my insurance company for my truck, I guess I'm getting a set of injectors.
