Problems after another...
Car: 1989 Camaro IROC-Z
Engine: 305 TPI Prochargered
Transmission: 700R4 Modified
Axle/Gears: 3,42
I just got engine back together, I port matched heads, changed cam, timing chain, Baseplate and runners. I fired it up few days ago and It didn't run very well...
First there was intake leak which caused backfiring through intake, fixed that. Then I got the engine running by timing way far advanced and idle screw to bottom (TPS and IAC tune ofc) After that I decided no matter what to run in the new cam.
I was just ready to crank it up, then car decided to blow fuel pump fuse few times. New fuel pump relay fixed that. Then spark lost...
Today I tested Coil and pick up Coil and found out that pick up coil wire was snapped. I'd make new wire and put new ICM. Then I was going to start the engine but doesn't crank... No fault codes, all fuses OK, I can hear the fuel pump and all in engine bay looks normal.
I've read threads, tech sites.. Now I'm running out of ideas..
Re: Problems after another...
You mean does not turn over, or turns over but does not fire? if it doesnt crank can you hear the starter "click". Start simple, then go from there....
Charged battery, cables tight. Connections at starter clean and tight. With someone holding the key in the crank position, do you have power on the small solenoid wire? If so, try tappin on the main starter body (not solenoid on top) a few times with a hammer or cycle the key quickly from crank to acc. If the starter starts to crank with either the hammer or key bump trick then you have a dead spot in the starter.....replace or rebuild
Axle/Gears: 3,42
Nah, nothing from starter.
I had similar problem about 2 years ago, but then guilty was VATS. If I remember correct, VATS issues will light up Security light?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Have you tried to jumper the starter enable relay ? Check your connections. The starter lead maybe loose on the starter
