passed smog with flying colors (Almost Flying)
1990 gat 5.0 five speed. It passed but I would like to see better results on the HC results. I've got two ears to figure it out. Any ideas would be great.
Here are a couple of photos. 2015 results and then this years.
Thanks for taking a look.
Bob
Bob
Transmission: Pro-built 700R4
Re: passed smog with flying colors (Almost Flying)
Need more info. When was the last time you changed cap, rotor, plugs, and wires? Oil changes regular? Have you cleaned the fuel injectors? When was the last time you changed your fuel filter?
Sorry Oil change just before this smog, everything else except injectors was done last time.
I use a fuel injector( Techron) on a regular basis. For this smog I ran a tank of fuel thru using Seafoam.
Bob
Bob
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
HC shows no change, but your NOx is slightly better. It passed so no worries until 2019.
That print out looks like a CA test. If you don't mind me asking, what CA county are you in?
Any engine mods?
Yes it is a California test. Live in Riverside county and in riverside city do we have to do the inhanced test.
The car is stock completely with no mods.
Im not sure how old the cats are or if they are original. I'm the fourth owner and bought it ten years ago in the Seattle Washington area. They do not test cars over 25 years old.
Bob
Bob
Next time use about a gallon of denatured alcohol to a 1/4 tank of gas. Retard the timing to 0. They will have trouble measuring it. LOL. I've got some pretty ugly things to pass smog this way. After the test promptly fill it with premium and reset the timing.
GD
GD
Car: 86 Trans Am WS6
Engine: 383 stroker
GD
GD
GD
GD
Car: '87 IROC
Engine: LB9
GD
GD
It can be done, but it needs to be undetectable.
Engine: LB9 305
Transmission: AT
I wish you were correct. cali did away w/ the rolling 25 year exemption. It is fixed at 1975 and older, no smog test.
In fact, a few years back, cali LOWERED the max allowable to BELOW the ca. max allowable, when the cars were almost new. cali's war on older cars.
Car: '87 IROC
Engine: LB9
I had passing measurements in 2009 which now failed in 2011. Yes, the car is currently registered.
