TPI base compatibility...
Old Jan 1, 2002 | 03:16 PM
MILT's Avatar
I tried searching, couldn't find the answer:
I have '87 TPI system on 305 w/ centerbolt heads, should the base fit an older SBC, or do I need an 85-86 base?
Thanks,
MILT
Old Jan 1, 2002 | 04:19 PM
Guest
Guest
Posts: n/a
To use it you have to modify the intake base, the center 4 bolt holes are at a slightly different angle. I've done it with both early and late TPI manifolds, although with a nice machine. I hear it can be done with a drill easily.
1992rs/ss
Jan 31, 2025 05:10 PM
Vintageracer
Jan 10, 2020 05:33 PM
Keith5
Aug 27, 2015 04:37 PM
355tpipickup
Alternative Port EFI Intakes
Aug 22, 2015 06:06 PM
Sanjay
Aug 12, 2015 03:41 PM
