86 TPI Starts and Stalls, have read every thread on here
Old Jun 21, 2017 | 09:30 AM
  #51
GeneralDisorder's Avatar
Re: 86 TPI Starts and Stalls, have read every thread on here
One is actually "startup coolant temp". I'm not sure exactly when that resets but it is indicating what the temp was on startup.
GD
Old Jun 21, 2017 | 09:35 AM
  #52
2012sergen11's Avatar
Car: 1987 Trans Am
Ok.
I took a look at the .adx file I got from the vendor who supplied my ALDL cable and it is named as an 85-88 lb9 and l98 file. Since I know the file cannot be the same for an 85 (different ecm) and I have found info here and on gearhead-efi that the 86 and 87-88 use different .ads files I am pretty sure this is part of the problem with the values.
Old Jun 21, 2017 | 09:53 AM
  #53
brianlibby791's Avatar
Car: 1989 Trans Am GTA
Engine: 5.7L 350 TPI (Deleted Cats)
Axle/Gears: Original 3.27
Originally Posted by 2012sergen11
So I was able to get a short log of the car while it started and stalled. Connecting the cable and setup was MUCH easier than I figured thanks to your guys' help and the help of the vendor where I purchased the cable (linked above).
Here is a snip of the data at the end of the log...
The only things that jumped out at me were the -40 MAT (Manifold Air Temp?) numbers and that the 2 coolant temps did not match.
I am not sure on the other numbers in the log and I am hoping you can point me in the right direction.
In the first log the MAT read -40 so I unplugged the sensor under the intake plenum which I believe is the correct onee and it still read -40 on the second log (pic above)
Just at a curiosity, how did you get that software and how did you hook it up to the obd1?
Old Jun 21, 2017 | 09:57 AM
  #54
Car: 1987 Trans Am
I purchased one of the aldl to USB cables linked earlier in the thread. The vendor explained the setup of the cable with a pdf they provided. Between the pdf and the guys in here, general disorder, tuned performance, and some others it was actually pretty straightforward.
The software is from Tunerpro.net
Old Jun 21, 2017 | 10:15 AM
  #55
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
The tps looks low in the one post .54v is spec. The Iat can be homed at the pigtail.
Looks to be a open circuit.
Old Jun 21, 2017 | 10:32 AM
  #56
Car: 1987 Trans Am
I need to adjust the TPS since I moved It a bit but .74v isn't too far off I would think for it to get running and stay running, but I could be wrong
Would the MAT/IATbeing open cause fuel cutoff ?
Old Jun 21, 2017 | 10:39 AM
  #57
Engine: Lb9
Transmission: M20
I'd think the Iat being open would cause a rich condition.
Old Jun 21, 2017 | 11:06 AM
  #58
I thought the MAF system IAT was only used for EGR?
I was looking at the $6E hac and thought I had found where it was used for something else but then I looked again last night briefly and didn't see it. But it was briefly.....
GD
Old Jun 21, 2017 | 11:10 AM
  #59
Engine: Lb9
Transmission: M20
GD
I use to think the same thing until I programmed out the egr for a customer and he left the iat out. According to him it ran rich.
Old Jun 21, 2017 | 11:37 AM
  #60
oddscrounger's Avatar
Car: 1987 IROC Z28
Transmission: TKO 600
Axle/Gears: 3.45 (G92 package)
have you replaced the ignition switch? I am thinking of replacing mine. My car runs great but once in a while shuts off out of nowhere (usually starting right back up almost immediately) as I drive down the road. The ignition switch seems like a likely suspect.
You've already gone down a complicated road but sometimes best to start simple. But now you are already on your way with the needed equipment to datalog and perhaps tune and burn chips. The path I want to be on myself, very soon!
Old Jun 21, 2017 | 12:02 PM
  #61
Car: 1987 Trans Am
Ok well since I am running very lean (needs ether to run) that may not be my problem
Hopefully changing the definition file this evening will make the log better and show some more useful info
Old Jun 21, 2017 | 09:50 PM
  #62
Car: 1987 Trans Am
So I changed the definition file in TunerPro to http://www.gearhead-efi.com/gearhead...227165_160.ads
This is one I had found linked elsewhere on the web. Some files i found that were named $32.ads but I could not copy the link.
With this definition I get the following
the output list is different than what I had last night and I am not sure on some of the constants, like airflow being measured in thousands
Also still cannot find anywhere to increase the sample rate, right now I am only getting 1 sample when it is running.
Old Jun 21, 2017 | 09:52 PM
  #63
Car: 1987 Trans Am
Well after a double check it seems this definition file is only for an 89 according to the comments in it
Old Jun 21, 2017 | 11:01 PM
  #64
Here's a startup list from my '86 running '89 $6E for data comparison:
GD
Old Jun 22, 2017 | 07:24 AM
  #65
Car: 1987 Trans Am
GD
Thanks!
Now if I can just get the right definition file
Going to have to become a member of gearhead-efi I guess otherwise i cannot get the files they have nicely organized
Old Jun 22, 2017 | 07:25 AM
  #66
Car: 1987 Trans Am
Is there anyway to change the sample rate in the program? At the bottom of my screen it is running at 0.7 Hz and I only get one frame of the car running before it stalls
Old Jun 22, 2017 | 09:47 AM
  #67
It's not a setting, per-se. The ADX file determines the sampling rate and communication protocol. You can "edit" the acquisition file and you will see the com protocol settings - baud rate, etc.
You need to get the proper $32 ADX and then it should just work on it's own. The protocol will connect once you jump in the 10k resistor. Get it connected and logging with KOEO and then start cranking.
GD
Old Jun 22, 2017 | 09:54 AM
  #68
Car: 1987 Trans Am
I have joined gearhead-efi so I can use some of their files, planning to use the $32.ads file from this thread...
http://www.gearhead-efi.com/Fuel-Inj...Information-32
Let me know if this looks right
Thanks again for all the help
Old Jun 22, 2017 | 10:08 AM
  #69
Should work. There's some here too:
http://tunerpro.net/downloadBinDefs.htm
GD
Old Jun 22, 2017 | 10:13 AM
  #70
Car: 1987 Trans Am
I used the file from that link to get the log yesterday, it is the definition file in the line for $32 ecm but in the text it says for 89?
Old Jun 22, 2017 | 10:40 AM
  #71
Vanilla Ice's Avatar
Car: 92 Trans Am Conv
Engine: LB9
Axle/Gears: 3.08
If the car starts and dies, it's probably not in the startup routines. It's the running routines.
Have you tuned the car recently or changed your ecu for anything?
Old Jun 22, 2017 | 10:47 AM
  #72
Car: 1987 Trans Am
No tuning on the car, stock memcal AUM code. Stock ecm that was in the car when I got it. Swapped with different ecm and memcal from a running car as a test with no change
Old Jun 22, 2017 | 10:59 AM
  #73
Engine: LB9
Axle/Gears: 3.08
Did the injectors start this issue?
If they don't flow the same as oem they can definitely stall you out.
Old Jun 22, 2017 | 11:04 AM
  #74
Car: 1987 Trans Am
Unfortunately i cannot say for sure. The injectors were replaced before i purchased the car. The previous owber said he had been driving it after and parked it due to needing an alternator and never got back to it prior to his divorce (reason for selling).
Unfortunately I don't know for sure that it ran after the injectors were replaced.
Old Jun 22, 2017 | 11:07 AM
  #75
Engine: LB9
Axle/Gears: 3.08
They are DEFINITELY suspect.
Take a picture of them and/or post part numbers on them.
Old Jun 22, 2017 | 11:16 AM
  #76
Car: 1987 Trans Am
I can get a pic and verify the number later but I'm almost positive the number is 01D062B, I looked them up to make sure they were the 19 lb ones when I first started working on the car.
Old Jun 22, 2017 | 11:21 AM
  #77
Engine: LB9
Axle/Gears: 3.08
Are the Pintle caps still on them?
Old Jun 22, 2017 | 11:35 AM
  #78
Car: 1987 Trans Am
I am not sure, would I be able to tell with them in the car ?
Old Jun 22, 2017 | 11:38 AM
  #79
Engine: LB9
Axle/Gears: 3.08
No, also look into the oil pressure switch. It cuts fuel if oil pressure doesn't hit the minimum limit.
Old Jun 22, 2017 | 11:45 AM
  #80
Engine: Lb9
Transmission: M20
The aum does have some bugs
http://www.gmtips.com/3rd-degree/dox/tips/ecm/prom.htm
Old Jun 22, 2017 | 11:57 AM
  #81
Car: 1987 Trans Am
I thought the oil sensor only applied additional power if the relay fails, not necessarily a cutoff?
Old Jun 22, 2017 | 11:59 AM
  #82
Car: 1987 Trans Am
Good info, may have to replace the memcal to avoid those. When I ran the car on my 87 memcal with g1 adapter for 89 mask it didn't correct my problem unfortunately but I'll definitely look into the memcal in the future
Old Jun 22, 2017 | 12:02 PM
  #83
It takes over powering the fuel pump relay after startup. So if your fuel pump relay is still powered then it's working.
GD
Old Jun 22, 2017 | 12:30 PM
  #84
Best thing to do is get an 89 PROM with the modifications for VATS delete, and fan n/o control, fan temp set points, 9th injector delete, EGR delete, etc. That will avoid the problem entirely.
Since you swapped over to a whole different computer for testing and it does the same thing I think we can rule out tuning issues for now.
GD
Old Jun 22, 2017 | 12:56 PM
  #85
Car: 1987 Trans Am
GD
Hopefully later I can get a new log with the new definition file later and see something suspect there. If not I have no idea where to go before starting to change out parts
Old Jun 22, 2017 | 09:02 PM
  #86
Car: 1987 Trans Am
I ran a new log with the $32.ads file in the link I provided earlier. I ran a log of the car starting and stalling like normal.
the output is the same look as before so maybe there was not a difference in the definition files.
I also ran a log letting the car run on starting fluid for a short time. If anyone is interested I can email the log. When the car was "running" the injector BPW stayed relatively steady but when the car began to stall the BPW went up a lot.
Running on starting fluid
Stalling out, Low RPMs
Hopefully you guys may be able to see something
Old Jun 22, 2017 | 09:31 PM
  #87
That seems like quite a few knock counts. I usually log a few on startup but it's like maybe 4 or 5 usually.
The data isn't being displayed correctly or the data is wrong.... That airflow number isn't in grams per second. It may be raw sensor data. I'll take a look at the formula being used in the $6E def and post it for you. You can change this in the acquisition editor interface.
GD
Old Jun 22, 2017 | 09:34 PM
  #88
Car: 1987 Trans Am
GD
The formula would be great, i am not sure why the airflow is being measured that way
would the knock counts being so high cause enough timing retard to stall?
Old Jun 22, 2017 | 09:45 PM
  #89
So to get grams per second you need to multiply your MAF number there by 0.003906
You can add this to the conversion tab in the acquisition values list.
GD
Old Jun 22, 2017 | 10:00 PM
  #90
I wondered about the timing thing. Mine seems to struggle at times when cold and now that I'm talking about this with you I'm wondering if those few initial knock counts are creating a situation where it's unable to get any timing.... although you should still have 6 degrees of base timing for it to run with.
I checked my log and my timing is at 0.70 degrees relative to reference pulse which would be 6.70 degrees. It slowly ramps back in about 2 seconds after initial start.
You could try twisting in about 20 degrees of timing and unplugging the ESC connector so it can't pull your timing....
GD
Old Jun 22, 2017 | 10:11 PM
  #91
Injector pulse width formula is multiply by 0.015259
GD
Old Jun 23, 2017 | 07:52 AM
  #92
Car: 1987 Trans Am
Thanks, I will look into it this evening and try to put in the formulas so that the data looks cleaner and is easier to interpret.
Do you know if the IAC motor position being 145 all the time is fully open or closed? I'm pretty sure that hasn't changed throughout the different logs I have run
Old Jun 23, 2017 | 10:29 AM
  #93
145 is the startup position. There is a couple tables that deal with the IAC position and the decay vs. coolant temp, etc. Once it enters closed loop it actually targets an RPM.... But yeah the 145 is normal.
GD
Old Jun 23, 2017 | 10:38 AM
  #94
Engine: Lb9
Transmission: M20
cl the iac steps are in the 20-25 range.
Old Jun 23, 2017 | 10:53 AM
  #95
Car: 1987 Trans Am
Okay good to know.
So with the conversion factors my MAF number and pulse width seem similar to what you (GD) posted above...
Is there something I need to do to get more data similar to the list above or is the limited data a side effect of the 86 prom and definition
Old Jun 23, 2017 | 12:48 PM
  #96
I think the problem is that no one really spent much time developing the $32 definitions. That data is probably there but due to lack of interest in the community it hasn't been hacked out of the data stream. Since most people either upgrade to $32B or $6E it isn't an issue.
Why don't you try using that $6E ECM from your other car and logging that?
Or send Tuned Performance a PM and he can set you up with a chip.
GD
Old Jun 23, 2017 | 12:52 PM
  #97
Car: 1987 Trans Am
GD
Reading my mind...
After seeing all the data in your log I was thinking of swapping the prom over to the $6E one I have.
Old Jun 23, 2017 | 12:54 PM
  #98
Car: 1987 Trans Am
What is the difference in 32B over the 86 $32 codes?
Is there any difference when using the newer $6E chip with the original coil in cap HEI fron 86 or does everything work the same in the computer?
Old Jun 23, 2017 | 02:47 PM
  #99
Engine: Lb9
Transmission: M20
$6e will be a plug and play, unless the fan setting is switched in that case the fans would run all the time.im not sure all the differences from $32-32b are I just prefer working with $6e.
Old Jun 23, 2017 | 03:57 PM
  #100
Car: 1987 Trans Am
I will plan on running a new log with the other chip and see how it looks.
Hopefully something will be visible there since nothing is jumping out from these logs as to what the problem is.
