86 LG4 to SD TPI base timing ?
Old Jun 20, 2017 | 11:22 PM
firestorm's Avatar
Car: Firebird
Engine: LG4
My LG4 sticker under the hood says to set the base timing to 0°. I'm installing SD TPI setup with an AXXB PROM. Should the timing still be set to 0°? Has to pass the emissions stiffer test at idle and at 33mph on the rollers. Thanks
Old Jun 21, 2017 | 01:22 AM
Fred SS's Avatar
Car: 87 Monte Carlo SS
Engine: 89 350TPI Transplant
Transmission: 2004r
Re: 86 LG4 to SD TPI base timing ?
If your installing TPI then the timing should be 6 degrees before TDC.
