89 formula 350
Old Jul 13, 2017 | 10:24 AM
Flows 89's Avatar
89 formula 350
My fuel pump keeps running even when the key is off any idea what might be causing this?
Old Jul 13, 2017 | 11:04 AM
thtanner's Avatar
Car: 1989 Pontiac Formula 350
Axle/Gears: BorgWarner 3.27 Posi
Re: 89 formula 350
the relay, or stuck oil pressure switch?
Old Jul 14, 2017 | 11:53 AM
Flows 89's Avatar
Re: 89 formula 350
Thanks that's where I'll start
Old Jul 14, 2017 | 01:51 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 89 formula 350
To test if it's the ops you can pull the fuse on the fender next to the battery.
