Replacing under hood fuel lines
Car: 91 Z28 - using 87 electricals
Engine: 383 HSR EBL
Transmission: 700R4 - Stage 3 Fixed Pressure
Axle/Gears: GM 3.08 POSI
Hi guys,
Next month next month I'm going to have a shop replace my fuel lines and brake lines front to back along with the fuel pump. I also want to replace the under hood lines from the fuel rails to the lines that lead to the back on my 350 TPI. A complete replacement part doesn't seem to be available so I was wondering what the board recommends for replacing the lines that hook up to the fuel rail and then connect to the rear trending lines.
Thanks in advance.
Thanks in advance.
