Intermittent maf problems ?
Car: 1986 IROC Z28
Transmission: auto
Is it possible to have intermittent maf issues ? My 86 keeps throwing an ses light and always seems to be a 33 or 34 code but comes and goes. I always thought mafs were either good or bad, not "going out". I hate to go buy another one and the problem persists.
Thanks for any advice.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Intermittent maf problems ?
Have you tried these tests ? Or is it too intermittent?
Sounds like a bad maf
http://www.chevythunder.com/maf_code_34.htm
Car: 1986 IROC Z28
Transmission: auto
Ive done that test but couldn't get repeatable results. It runs fine and no light, then I'll get a hiccup while driving and the light comes on. I reset the code and it's off for a while but always comes back.
Engine: Lb9
Transmission: M20
You might be able to find a good used Bosch maf in the classified section someone parting out a tpi car 86-89. I have seen good used ones go for aslittle as $50-60.
Ask this member 89irocz355
https://www.thirdgen.org/forums/member.php?u=37644
