compression test results on a 307,69 chevelle
Old Aug 19, 2017 | 09:43 PM
therat's Avatar
Want a title? Post!
what is considered good compression test results.
Old Aug 25, 2017 | 05:13 PM
Fred SS's Avatar
Car: 87 Monte Carlo SS
Engine: 89 350TPI Transplant
Transmission: 2004r
Re: compression test results on a 307,69 chevelle
From what I have read about engine compression tests is that you are not looking for an absolute value. Your looking for consistency among the cylinders. Years ago, I did a compression test on an 70's oldsmobile cutlass that I did a backyard novice engine overhaul on. Honed the cylinders with a drill operated hone and installed new rings. Not something I would do again. I remember I got somewhere around 130 - 140 psi on all cylinders except one. That cylinder was 50 - 60 psi.
tylercamaro
Oct 28, 2010 02:18 PM
onebad82z
Carburetors
Oct 12, 2004 08:08 AM
