Charcoal Canister
Old Aug 20, 2017 | 09:41 PM
Peter Bowen's Avatar
Charcoal Canister
I looked high and low and don't have an answer, so maybe you guys can help. I'm in California, so I need to pass smog.
The charcoal canister appears to have holes... holes... in the side where the plastic has rotted. I found a few part numbers, but they've all been discontinued.
can I cobble together a system that works using a generic canister? Is there somewhere else that I should be looking? The plastic on these is old enough... would a bone-yard canister be worth even installling?
Old Aug 20, 2017 | 11:05 PM
Chopski's Avatar
Car: 1989 IROC
Axle/Gears: 3:42
Re: Charcoal Canister
You can get new.
https://www.summitracing.com/parts/a...BoCH-8QAvD_BwE
Old Aug 20, 2017 | 11:37 PM
If only... So if I get that one, how do I plumb in the electronic solenoid that is on the top.
I found this one that looks close...
https://www.classicindustries.com/pr...ts/g11692.html
Are these different between the v6, 305 and 350 motor?
Old Aug 21, 2017 | 09:33 PM
NoEmissions84TA's Avatar
Did you see this?
https://www.thirdgen.org/forums/engi...-gta-evap.html
Old Aug 22, 2017 | 12:51 AM
Great - totally interested, but can't reply... can you ping the seller for me?
Old Aug 23, 2017 | 02:51 AM
DONE.
Old Aug 23, 2017 | 10:36 AM
Thanks - i sent him a PM too...
Old Aug 23, 2017 | 10:38 AM
Has anyone taken one of these apart? Is it the sort of thing that I could replace the canister with a metal (spun aluminum maybe) canister and silicone or otherwise seal it up? I have a couple of lines on used parts, but I would love to machine it out of something more durable.
Old Aug 24, 2017 | 04:04 AM
https://www.thirdgen.org/forums/tech...ebuilt-my.html
Old Aug 24, 2017 | 10:10 AM
I read that one before, but I wasn't sure if I had the same one, since it's a California car, and the system is supposed to be sealed... It looked like his was not sealed, but open to the atmosphere on the bottom. I suppose I should just pull it apart and have a look.
Old Aug 24, 2017 | 12:54 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
None of the GM charcoal canisters of this era are sealed. They are all vented to the atmosphere. As such there is never a pressure build up in the canister.
As for your question of which canister to get. They not only varied over the years, but also varied for different drive-trains of the same year.
RBob.
