Temp gauge reading high
Old Aug 23, 2017 | 09:14 PM
jorgeblancojr's Avatar
305 TPI. My temp gauge is always reading high. I don't even have to start the car and it'll go up slowly with the key turned. I disconnected the connector for the switch near the 1 and 3 plug and the needle went down to 100. New gauge and new switch.
Old Aug 23, 2017 | 09:38 PM
rbrackett's Avatar
Re: Temp gauge reading high
Replace you temp sensor. It likely crapped out with old buildup.
Then...flush your coolant system, refill with 50/50 mix, make sure there are no leaks. That's a good start.
