Injector flow testing
Has anyone had there injectors cleaned and flow tested. I have a 383 TPI with Accel Super Ram and 1985 Corvette injectors. I'm in the process of changing the intake manifold to a Accel base and was wondering if it is worth having the injectors flow tested while it's apart.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Injector flow testing
Those injectors are small for a 383 if there stock from 85 22#hr. Unless you have raised fuel pressure.
If your going to have them services at $15-20 or so a pop you might as well invest in new injectors.
327_TPI_77_Maro
Oct 3, 2017 02:43 PM
