10K resistor - change the driving characteristics of the car
Old Oct 5, 2017 | 11:31 AM
Peter Bowen's Avatar
Hey - quick question - when I put the car into ALDL mode (10K resister) , it increases the idle - significantly - 1200 rpm and 700 in drive. Is there a good reason that it does this? if not, does anyone know how to fix it?
Old Oct 5, 2017 | 11:39 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 10K resistor - change the driving characteristics of the car
Remove the 10k resistor. It tells the ecm your in field service mode and to symtart data flow. Timing locks and rpm will raise as per programming .
Old Oct 5, 2017 | 12:00 PM
Right - when I remove it, it stops sending data. Is there a trick to starting the data flow and keeping it going after the resister is removed? (1988 Formula 5.7 TPI)
Old Oct 5, 2017 | 12:02 PM
Engine: Lb9
Transmission: M20
Welcome to the 165 ecm
Old Oct 5, 2017 | 12:11 PM
I don't think it's field service mode because the light doesn't flash while the engine is running and I'm data logging. It should flash to indicate rich/lean in field service mode, right?
Old Oct 5, 2017 | 12:24 PM
Engine: Lb9
Transmission: M20
http://forum.tunerpro.net/viewtopic.php?t=2215
Your correct on fsm
