pontiac firebird wont start
Old 10-14-2017, 01:30 PM
abi
Want a title? Post!
abi's Avatar
my pontiac firebird 3.1 1991 wont start i change .she start only with start pilot for 2 second why
Old 10-14-2017, 08:44 PM
Pro
Pro's Avatar
Car: 1992 Z28 and 1995 Silverado
Engine: 5.7 TPI and 5.7 TBI to TPI convert
Transmission: 700R4 and 4l60E
Axle/Gears: G80 3.23 and open 3.42
Re: pontiac firebird wont start
comment vont les choses en france
I would check for fuel pressure. I dont know where the schrader valve is on a 3.1. You may want to post your question here for more responses:
https://www.thirdgen.org/forums/tech-general-engine/
Old 10-14-2017, 09:11 PM
Tuned Performance's Avatar
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Check fuel pressure, if that’s ok 43.5 than vats
A hz signal is sent to pin f10 of the ecm a blue wire. If you get 30-50hz @ 50-60% the passkey is working. You can also check with a volt ohm meter and should see 2.5 volts.
dr_tao
09-05-2022 09:26 AM
Redemption
03-09-2017 08:57 AM
evlbeak
11-22-2016 12:02 AM
marald
Carburetors
01-30-2001 03:45 PM
steven
Car Audio
01-14-2001 11:11 PM
Quick Reply: pontiac firebird wont start
