Tips on tracking down misfires?
Old Oct 31, 2017 | 05:37 PM
Shakenblake's Avatar
Car: 1988 camaro iroc z
1988 305 tpi, new fuel pump, distributor cap and rotor, wires and plugs changed 3 months ago but that was before the crappy leaky injectors got replaced. Anyone have tips on narrowing down misfires.? P.S. ignition coil checked out with multimeter. But i did not test pick up coil. Thanks......
Old Oct 31, 2017 | 05:47 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Tips on tracking down misfires?
Start pulling plug wires or injector connectors to narrow it down to a cylinder.
Old Oct 31, 2017 | 05:49 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Axle/Gears: G80 3.23
Can you do a compression check?
Cut fuel to the pump, turn key, listen for bad compression
Old Oct 31, 2017 | 11:57 PM
Jbuchanan's Avatar
Car: 1987 GTA
Engine: 5.0
Transmission: Automatic
Insulated spark plug pliers are nice. Car running at idle and pull wires one by one. If you pull one and notice no stumble or hesitation that cylinder is missing.
