bad pump?
Old Nov 10, 2017 | 10:19 AM
wruiz's Avatar
Car: 1990 Iroc z-28
Engine: 350 TPI STOCK
bad pump?
I have a non start issue. It's a '90 5.7 with HSR. I have spark and good injectors. With key "on" I have no fuel pressure on the gauge but I can "hear" the relay clicking, also I "think" I can hear "some" noise in the tank. However, when I bridge (orange and grey wires) the relay plug I can see some pressure slowly building up in the gauge and a weird noise in the tank like a vibration. The vibration stays as long as the wires at "bridged". The pressure stays at around 30. Could it be bad relay, bad pump, or both? Thanks.
Old Nov 10, 2017 | 10:37 AM
jkris53406's Avatar
Car: 87 Formula, 91 Trans Am
Engine: 355 tpi, 305tpi
Transmission: 700r4, 700r4
Re: bad pump?
A relay is a much cheaper start. If you jump the relay and the pump runs, start there.
Old Nov 10, 2017 | 06:00 PM
LiveIt!'s Avatar
Car: 1988 Camaro Sport Coupe
Engine: The All-Powerful 2.8l!! :P
Re: bad pump?
It sounds like the pump is running but rough. Another way to test is if your ALDL has a G terminal (facing the ALDL, far lower left terminal) apply 12V there, that's about the same as jumping the relay.
Old Nov 10, 2017 | 09:16 PM
thtanner's Avatar
Car: 1989 Pontiac Formula 350
Axle/Gears: BorgWarner 3.27 Posi
Re: bad pump?
I like to test voltage at the connector under the rear of the car with a multi meter when things at the relay are testing good. That's the second to last leg to the pump (the last leg is the connector on the top of the sending assembly - mine had a wiring fault there)
Make sure you're getting your voltage to the connector there, then you can use a 12v source to prime the pump direct too just to be sure.
