Will 3" valve covers fit an 88 Iroc?
Car: 79 Monte Carlo
Engine: 406
Transmission: 2004-R
Axle/Gears: Phord 9 inch/3.90
Will they fit? The stock covers measured 2". The problem is, my motor is all apart, and I cant remember how close the alternator was to the valve cover. I would like the taller valve covers for roller rocker clearance. Any thoughts? Thanks in advance, Jeremy
They should! I have M/T cast aluminum valve covers that are 3 1/4" tall (from gasket surface to top of fins) and they cleared the SLP runners.
Mike
Edit: I reread your post.......the M/T's also cleared the alternator (87 V-belt setup in my case.....alternator is on the passengers side)
Mike
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
They hit the power outlet on my alternator on 89 firebird, so I had to beat the valve cover a little bit with a hammer.
I'm using the sportsman-II heads, so I use the parimeter covers rather than those stupid centerbolt ones.
-- Joe
-- Joe
NBrehm
Aug 25, 2015 11:49 PM
