Air Intake parts to convert 1986 TA from MAF to MAP
Old Dec 17, 2017 | 09:39 AM
Bogey's Avatar
Car: 86 Trans Am
Engine: 350 TPI professionally built
What parts/ kits are needed regarding the air intake to convert a 1986 TPI TA from MAF to MAP?
Old Dec 17, 2017 | 10:22 AM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: Air Intake parts to convert 1986 TA from MAF to MAP
In all reality, you don't need to change any of the intake duct work to run a map. The maf sensor is just a tube then. You could just run and open element on the front of the TB if you don't mind hot air going to the engine (I wouldn't go that route myself) Otherwise, just look for a 90-92 firebird intake. Both v6 and v8 are the same. They make it to the classified boards every so often. You could put a WTB for one if you feel so inclined.
Old Dec 17, 2017 | 02:18 PM
Bogey's Avatar
Car: 86 Trans Am
Thanks so much for the quick response and input!
Old Dec 17, 2017 | 02:21 PM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
Just for your info., you do realize you will need a map ECM also.
Old Dec 17, 2017 | 03:33 PM
Bogey's Avatar
Car: 86 Trans Am
Absolutely along with some rewiring and programming for my mods as well. Appreciate all the help on this forum!
gbettner
Mar 31, 2013 05:30 PM
chevyguy1969
Feb 12, 2009 02:36 PM
3.8TransAM
Apr 20, 2005 01:35 AM
Hawk4Me
Jun 12, 2003 12:15 PM
