Bigger Gaskets???
Car: 1987 IROC-Z
Engine: 5.7L TPI
Axle/Gears: Borg Warner 9 bolt with 3.27
Bigger Gaskets???
Pulled my plenum, runners, and fuel rail the other day and discovered that PO had attempted to port the runners and hacked up the intake manifold a bit as well. I think it can all be cleaned up just fine but I am looking for a source for some oversized gaskets that I can match to. I'm hoping that I can clean up the porting to match the larger openings in the gaskets. What would you all recommend for the gaskets?
Engine: 4++,350 & 305 CIs
Car: 1987 IROC-Z
Engine: 5.7L TPI
Re: Bigger Gaskets???
Guess I should have asked for recommendations on the manifold to head gaskets as well. I have yet to pull the manifold but I'm assuming stock sized gaskets will be too small as well. Thanks.
Stock will most likely work, I like fel-pro 1204 or if bigger is needed 1205, 1206
