which head gaskets/intake gaskets??
Old Jun 27, 2001 | 08:35 PM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
replacing leaky head gaskets and need recomendations.
saw some differing kinds on summit page but all of them say they are for 305 and 350.
is this possible to put a 4.060" gasket on the 305?? or do they all just work the same?
and what brand of intake gaskets do ya'll use.
thanks for any and all recomendations.
James.
88 WS6 T/A 305 TPI--
K&N,Air foil,hypertech chip, thermostat+fanswitch
free mods, dynomax catback, urethane motor+trans mounts,
SSM SFCs, Bilsteins
very trick homemade ramair, Accel 300+ ignition system.
Planning: hedman 1-5/8 longtubes, NOS 150 plate, world 305 heads, replace the "peanut"! and other susp. mods.
check it out at:
http://www.geocities.com/transam617
Old Jun 27, 2001 | 08:44 PM
Vader's Avatar
88,
Yes, the gaskets are interchangeable. There are only a few exceptions, but otherwise the bore siszes of most common SBC head gaskets are the same size. Most of then can be used on 400 CID SBCs at close to stock bores. There are some specials for bored 400s.
Fel Pro has reliable gaskets, and so deos the GM parts counter. Gaskets are one item that you will generally find cheaper at the dealer, and they are not reduced quality. I get rebuild set for about $100.00 less at the dealer (Fel Pro, $288.00, GM $193.00 for LT1/4 engines).
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
Old Jun 28, 2001 | 05:39 AM
ede's Avatar
ede
fel pro is all i buy or use in my engines. never had a problem with them in the 25 years or so i been doing this. victor also makes so great gaskets as do a few others, but i like fel pro.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Jun 28, 2001 | 07:18 AM
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
great thanks guys.
James
3rd gen money
Sep 8, 2015 11:40 PM
355tpipickup
Aug 27, 2015 08:13 AM
NinjaNife
Aug 23, 2015 11:49 AM
qz6lwp
Aug 20, 2015 08:10 PM
