ohming the ICM and ESC
Old Feb 21, 2018 | 10:16 AM
happyhapka's Avatar
Car: 1986 Trans AM WS6
Engine: 383 Vortec TPI, PUTS SMILES ON FACE
Transmission: PATC LVL 3 Raptor Transmission
Axle/Gears: 3.27 POSI 9 BOLT
I have a multimeter but cant find a diagram on what pins to probe with what .. does anyone have one? the car is an 86 trans am tpi.
Old Feb 21, 2018 | 10:26 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: ohming the ICM and ESC
The esc circuit would cause a code 43 if it malfunctions.
Old Feb 21, 2018 | 02:19 PM
happyhapka's Avatar
thank you very much. I just want to check it without having to take out my cap and rotor...
I have a weird issue.. I just want to trouble shoot. but it could be plugs. I have not pulled them out yet.
Old Feb 27, 2018 | 05:46 AM
Vader's Avatar
Care to describe the weird issue?
Old Feb 27, 2018 | 10:28 AM
happyhapka's Avatar
sure ill do the best I can, its really weird.(its my gremlin with my car)
so she was running pig rich, afr was 12.0+/- afr constantly, timing was wacked. ran rough and like poop, you could hear it through the exhaust as well it was as if it was running off 7 cylinders, maybe less, but the weird thing is that I just got tunerpro rt and swapped over to the $6E bin and that's when she started running like crap. after trying a couple of tunes she still ran like *** so I ended up even going back to my stock tune and she still ran like crap. well I let the car sit for a couple of days and when the weather cleared up a bit I decided to pop in this new $6E bin again and drive it, so I did, at first she ran like **** than about 15 minutes into the drive BAAAAMMM!!! I had all power + some more back, she has been running great since then. I know my maf was bad but had it unplugged, and still do,,, but when she was running bad she wouldn't even idle with it unplugged.
I'm thinking my ecm is intermittent going bad, and will be getting a new bosch maf unit.
since than the car has been great, I did check the timing and it was at 4 degrees so bumped it back to 6. I thought maybe it was a bad distributer but I'm not sure, I'm going to replace my ecm just to be sure.
so ya, its a gremlin.
Irockirocs
Jun 3, 2012 08:31 PM
Black'92
Mar 3, 2011 08:17 PM
johnny89345
Mar 5, 2009 03:07 PM
jerflash
Nov 11, 2007 06:13 PM
CRAZYCHUCK13
Jun 26, 2006 09:43 AM
