stock 350tpi injector ohming
Old Mar 5, 2009 | 01:29 AM
johnny89345's Avatar
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
what should the injectors all ohm out at? what if there all too high
Old Mar 5, 2009 | 01:58 AM
Saculia's Avatar
Car: currently a 91 G92.
Engine: 305TPI
Transmission: Borg Warner WC 5 speed
Re: stock 350tpi injector ohming
They should ohm above 14 ohms. All 8 injectors should be very close to each other. Anything below that is probably on its way out.
Old Mar 5, 2009 | 02:04 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Yes, above 14 ohms when cold and when warm. Anything less than 12 ohms when warm and its bad.
Old Mar 5, 2009 | 02:45 PM
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
mine are arre all reading 17.9-18.1
Old Mar 5, 2009 | 03:07 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
That is fine.
specialized
Jun 18, 2022 09:26 AM
Brcharrelson
Aug 26, 2015 07:47 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
1989formula5.7l
Aug 15, 2015 11:35 AM
