Plenum to runner Hi-flow gaskets
Old May 7, 2018 | 02:06 PM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
Where does one find the plenum to runner gaskets. I have the Edelbrock 3865 large runner. All the gasket kits come only with the runner to base gasket. Who does that? Stupidest thing I've ever seen. $70 for half the gaskets .Ridiculous. Anyway can the stock one be cut out enough?
Old May 7, 2018 | 04:58 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Plenum to runner Hi-flow gaskets
You might look into mr gasket 146
Old May 11, 2018 | 06:47 PM
fullsize fun's Avatar
Car: 1986 pontiac bonneville
Engine: LB9 305
Transmission: MK6 T5
Stock ones work fine, the runner ports are not bigger than the stock gasket bores. I just installed a set on mine.
Old May 11, 2018 | 07:07 PM
Engine: Lb9
Transmission: M20
In that case use mr gasket 145 or felpro MS93160
https://www.summitracing.com/parts/f...iABEgLJb_D_BwE
Old May 13, 2018 | 07:22 PM
Flycaster1977's Avatar
You can get a larger port set from tpis.
Old May 13, 2018 | 08:09 PM
Engine: LB9 305
I just installed a brand new set of NIB edelbrock Hi flo runners , stock gaskets where plenty big.
chanrahan
Jun 20, 2017 10:11 PM
gmendoza
Jan 5, 2010 03:06 AM
d4nk
May 7, 2002 06:22 PM
JETHROIROC
Mar 21, 2001 12:15 PM
