Vortec heads with LS6 spings "and" retainers?
Building a budget TPI motor with LT4 hot cam and Vortec heads.
I know its common to use the LS6 spring but everyone says to use the Comp retainers. Is there any reason I can't use the LS6 retainers I already have them and free is a lot better than $75.00 if I can use them.
Car: 1983 G20 Chevy
Transmission: 4L60
Re: Vortec heads with LS6 spings "and" retainers?
Comp 787 is what you want for a standard SBC Vortec head with LS6 springs.
You could also consider LT4 springs, 10° locks, and titanium retainers. Under a Benji for the whole lot:
12495494 https://www.gmperformancemotor.com/parts/12495494.html
12495492 https://www.gmpartsgiant.com/parts/g...-12495492.html
12495503 https://www.gmperformancemotor.com/parts/12495503.html
LS valve stems are 8mm (about .3149"); SBC are 11/32" (.34375")
Gotta use retainers that have the LS spring outer dia but fit your stems. Which is, Comp 787. There may be others but that's the one I know of offhand. There are no stock ones with the right combo of dimensions, obviously.
Bullydawg
Sep 24, 2018 08:26 PM
quick90rs
Jul 13, 2015 07:10 PM
KiLLJ0Y
May 10, 2011 04:32 PM
wildjyoung
Jun 11, 2007 11:37 AM
