89 formula 350 fuel problem
Old May 9, 2018 | 11:55 AM
Garthman's Avatar
So I bought a 89 formula 350 that hasn't ran since 2002. I've done a tune up on it, new fuel pump, checked fuel lines, checked fuel pressure regulator etc. I'm getting spark but feels like I'm not getting fuel. Maybe it's the injectors but would all of them be bad? I've had it running from spraying gas in the plenum but that's it.
Old May 9, 2018 | 12:11 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 89 formula 350 fuel problem
Have you checked injector pulse with a noid light ?
I would change the injectors contact South Bay fuel injectors.
If they are stock multecs they are junk. Sitting for so many years I would bet they are all clogged stuck shut.
Old May 9, 2018 | 12:18 PM
Garthman's Avatar
I haven't yet. My noid light doesn't work properly so I'm gonna have to pick one up probably tonight if they're not expensive. Injectors shouldn't be too hard to change right?
Garthman's Avatar
Old May 9, 2018 | 12:20 PM
Engine: Lb9
Transmission: M20
Injectors are pretty easy to change. The runners and plenum need to be removed. Here’s what multecs look like.
Old May 9, 2018 | 12:23 PM
Engine: Lb9
Transmission: M20
Btw you need 22#hr injectors. You can get gaskets from them too.
https://www.southbayfuelinjectors.co...-injectors/tpi
If you mention your a tgo member you can save 10%
Old May 9, 2018 | 12:27 PM
Garthman's Avatar
Thanks man, I'm gonna have to check out south bay.
Old May 9, 2018 | 01:45 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
You can use just a regular incandescent bulb in place of a noid light. Just needs to have some resistance so you don't burn out the driver in the ECM? Someone correct me if I am wrong. I usually just bend the legs out from a 194 bulb and stick that in the injector connector.
Old May 9, 2018 | 04:01 PM
TallTim's Avatar
Car: 1989 Formula T-Top
Engine: 350 TPI, twin turbo
Fellow 89 Formula 350 owner here. I suggest you not remove the plenum to get to the injectors unless you know you have to. I didn't see mention of testing the resistance to them. They should all be close. Make sure the wiring harness is properly seated on each injector. One bad one or one bad connection can ruin your day.
Old May 9, 2018 | 04:15 PM
Garthman's Avatar
I pushed down on them to make sure they were all connected. I guess for it not being run in so long the injectors could've went. And just to rant, is the filler neck connected to your gas tanks as well? Because that sucked dropping the tank.
Old May 9, 2018 | 04:21 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Yes, all 82-92 have a connected filler neck
Old May 9, 2018 | 04:23 PM
Garthman's Avatar
I tell ya, I didnt mind dropping the rear end but that gas tank drove me crazy. And is putting the 22lbs injectors in it going to give me noticable performance?
Old May 9, 2018 | 04:49 PM
Garthman's Avatar
Could it be my oil pressure sensor?
Old May 9, 2018 | 07:17 PM
Engine: Lb9
Transmission: M20
Stock size injectors for a 350.
I wouldn’t worry about injector impedance if they are multecs. The coils fail when warm in your case you have a no start.
Old Jul 10, 2018 | 08:29 PM
Garthman's Avatar
Alright, new fuel filterxblew out the gas lines. Checked injectors with noid light(they are pulsing), and did fuel pressure test (goes up to 45psi). Now it cranks and makes popping sounds like it wants to start. I'm assuming its definitely my injectors being that they sat for so long. If someone has a different thought can you point me in the right position?
Old Jul 10, 2018 | 08:39 PM
Engine: Lb9
Transmission: M20
https://www.thirdgen.org/forums/afte...romo-code.html
Sounds like there gummed up with varnish .
Old Jul 10, 2018 | 09:25 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Yup, injs are gummed up. Can sometimes remove the nasty stuff with lacquer thinner and pulsing them but honestly if they are the original multi-tecs, do yourself a favor and replace them.
Old Jul 12, 2018 | 10:28 PM
MrPackstin's Avatar
Car: 1989 GTA
Engine: 5.7 w/Paxton
Definitey do an ohm test on those multecs.
Old Aug 4, 2018 | 06:27 AM
Garthman's Avatar
UPDATE: finally bought some southbay injectors, good people btw, and she started right up. Had to mess with the timing for 5 minutes and now she idles smoothly. Now to check the rear diff fluid, pump up the tires, and see if she'll go up the road.
91moneypit
Apr 22, 2013 10:42 PM
ZenShaman
Sep 10, 2012 05:38 PM
Dante93GTZ
Oct 18, 2010 05:16 PM
stealth908
Sep 23, 2008 04:52 PM
tpi-hearse
Exterior Parts for Sale
104
Jun 18, 2008 11:39 AM
