Any difference between Camaro and Firebird Engine Harnesses
Old Jun 3, 2018 | 01:24 PM
91RS5speed's Avatar
Car: 91 RS
Axle/Gears: Auburn Pro / 3.42
Is there any difference between the engine harness? If so what is the difference. I picked up a 1991 Firebird TPI harness and it looks like some connections are on the other side of the harness.
Also how hard is it to pull the ECU connector though the fender? Do I have to pull the fender off to do it?
Last question is do the 1991 Corvette ECU and F-Body ECU use the same prom?
The reason for all of this is I am currently running a 1991 Corvette computer with a stand alone harness. I would like to make the install look factory and get back cruse control, power steering, and ac notifications to the ECU.
6SpeedTA95
Oct 28, 2005 04:32 PM
83TransAm
May 5, 2004 12:00 AM
Jiffy
Mar 8, 2001 09:38 AM
89FirebirdUK
Dec 1, 2000 08:42 PM
