Opinions for a street cam and heads 305 tpi 5 speed car
Old Jun 25, 2018 | 08:36 PM
Aaron709581's Avatar
I'd like to just dump my stock 305 heads since the valve seals are worn and build some power with just after market heads Nothing super agressive "used or new" and a streetable/strip cam .
I believe I read the 5,speed 305 cars came with a better cam then the autos. But obviously I'm looking for more power to wake the car upbwhere all the stock stuff can't.
Goal is to keep it cam and heads maybe bigger injectors. I don't wanna go all out but I want a nice lope to the whole setup without having to do any other mods besides heads cam and new gaskets on all the parts it takes to get the job done.
Any combo ideas? And if I ever decide to go 5.7L Id like these heads to be swappable.All in all I want more power cars a dog just like any other stock 80s 90s econo motor seems to be no different then the 5.0 came in the 89-93 tbirds.
Old Jun 25, 2018 | 09:33 PM
PaulyC's Avatar
Re: Opinions for a street cam and heads 305 tpi 5 speed car
The only info I have to offer is if you plan on going >=350 don't waste money on heads now. You will not be able to get a set of heads the will work well on both the 305 and the 350. The heads you will need/want for the 350 will not fit (specifically the valves) in the small 305 bore.
Old Jun 26, 2018 | 02:39 AM
Drew's Avatar
There's still time to put that can of worms down, there's no need to open it. 305s are slow. Nothing is really going to change that. But still, if it feels like a Ford Luxobarge, you might want to determine exactly what you're working with. From your other posts, it sounds like the car has been messed with a bit. Is it still the original engine? Dual cat car? G92? What gear ratio is in the rear end?
If someone swapped in whatever TBI 305 they found laying around, and you've got 2.77 or 2.73 gears, yeah it's going to feel slower than molasses in January.
Old Jun 26, 2018 | 05:32 AM
No it's not hacked it's original 305 tpi... Not tbi
Old Jun 26, 2018 | 06:48 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Just recondition stock heads
Cam wont do much without supporting intake mods and definitely will need tuning
Only set of heads to run that could swap over to a 350 would be trickflow small bore 175’s but they are small for a 350. Oem vortecs with 1.94 valve could work but you would need vortec base.
Lot of money to spend for little gain
We did a cam only L98 and it only made 224 whp. Basically no gain
Old Jun 26, 2018 | 07:05 AM
Im seeing the point here .. no way but to just put in a 350 and mildly build that. But if I find a 350tpi do I have to go with a oroginal Camaro tpi block or will the 350 tpi setup work on any 350 4 bolt main build . Seems people wanna make it easy and run 350 tpi blocks
ill convert the tpi over but I warntw sure how hard it would be to run across a original Camaro 350 .Say I go online or find someone with a used but built long block 4 boly main and I get the tpi upper end will it convert ?
Old Jun 26, 2018 | 07:14 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
I should say if you wanted to heads cam 305 or really just cam the stock head 305 you will need to ditch tpi for something that can rev like a stealth ram or proflo or singleplane
You can put tpi on any 350 block and heads, may have to oval the center 4 intake bolts. Only thing is tho, you should try to maintain the oem hyd roller cam stuff found in 87-99 roller blocks. Makes cam swap cheaper as you can use ls7 style lifters which are 200$ now instead of buying retrofit parts
Tpi kills power in any case. If you want tpi best bet in the end is a First unit or find big mouth type base and large tube runners
Old Jun 26, 2018 | 05:00 PM
fireball451's Avatar
Car: 91 Z28, 91 Z28, 92 Z28
Engine: LB9, LB9, L98
Transmission: T5, T5, 700r4
Axle/Gears: 3:42, 3:42, 3:23
Heads on a TPI 305. GM Vortec heads are a good replacement and work well with the 305 (can be used later on a 350). There are articles out there about putting them on a 305.
A stock LT1 cam is a mild upgrade. It is slightly bigger than the 305 G92 cam.
Old Jun 28, 2018 | 10:35 AM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
I did this years ago for the 305.
-Vortec heads
-ZZ4 cam
-SDPC intake
-Shorty headers
-Large tube runners
-1094 felpro .015 head gasket
made 257 RWHP and the car ran 13.50 at 101 MPH in the 1/4 with the 5 speed.
Old Jun 28, 2018 | 10:39 AM
What would that setup cost me? forget the exhaust I'm having that done anyhow. If the heads are used but good what am I looking at roughly in expenses new cam used good heads. Did you use the stock tpi stuff and injectors did u delete any ac stuff and emissions stuff
khulsebus
Mar 3, 2015 09:36 PM
87TTops
Aftermarket Product Review
Nov 23, 2007 10:03 AM
KZad
Feb 26, 2003 03:25 PM
91RS5.7TBI
Oct 16, 2001 09:24 AM
Godti
Jan 30, 2001 12:27 PM
