Do 305 TPI heads flow better than 305 TBI Heads?
Car: 88 Formula, 04 CTS-V, 06 Commander
Engine: 305 TBI, LS6, 4.7 V-8
Transmission: 5 spd, B&M Short Throw
In doing a mild modification to my 88 formula's LO3, would it make sense to upgrade to the TPI heads, if I could get them cheap enough (under 100 bucks.) This way I could also send them to the shop to get done (any suggestions?) prior to tearing mine appart.
By mild modification, I mean CAM, INTAKE, AND HEADERS.
Kurt
Kurt
Transmission: 4L80E/4L80E
Do TPI heads flow better than TBI heads? Without a doubt.
What to do to TPI heads? 1.94" intake valves, porting (bowl work and guide reduction at a minimum), screw-in rocker studs, real valve springs and seals.
Car: 2007 Corvette Z06
Engine: LS7
Transmission: 6 speed
I would go vortec (maybe pro topline version) or really cheap 305 TPI heads (like less than $50 including shipping) and plan on doing your own porting or else I doubt they'll be worth the money.
My 305 TBI is only .1 sec slower than my 305 TPI was with the same mods. I do plan on porting and getting a valve job on my 081 heads then putting them on the TBI later, but that's b/c the heads are free for me and I already have the equipment to port them myself.
I'm hoping to get my 305 TBI into the 13s on the stock LO3 swirl ports.
Car: 88 Iroc
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
The stock 305 tpi heads have 1.84 valves.
Engine: LS7
But how much does it cost if you were to pay a machine shop to do all the work? I imagine the porting alone will cost a few hundred, plus the normal for a valve job, screw in studs etc. Paying someone else to make the stock heads good will cost almost as much as an aftermarket set of heads. Just a thought.
So the general decision is to not worry about doing the TPI Heads (that i can get for ~$75), but to get a cheap set of Vortec's for around 500-600. How hard is it to do the work to them anyhow? Just dremel work, or some serious stuff? I think I did a pretty good job doing my throttle body, for example (pic below).
Any other suggestions?
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Car: 1986 Irocz
Axle/Gears: 3.25:1
Engine: LS7
yeah and a $50-80 electric grinder plus ~$10-20 for a speed control, a dremel won't cut it. I agree if you do the porting yourself it could be cost effective, but you're looking at probably 10+ hrs of porting alone, plus the chance of messing the heads up.
I'd say for a mild 305 TBI if the cam is small enough(like a LT1 or L98) find some stock vortec heads used for a few hundred dollars and be done, the vortec carb intakes aren't very expensive. I imagine if you look in junkyards you could pick up a set of vortecs for $200 or so.
I'm not saying porting the 305 TPI heads is a bad idea (I'm probably gonna do it myself), but for a mild 305 you're not gonna have(need) a cam requiring work to be done to the stock vortec heads making them perhaps a better option.
Car: 89 RS Convertible (Original owner)
Axle/Gears: 3.73 With Zexel Torsen Ltd. slip
While we're on the subject, are certian year tpi heads better than other year ones?
Engine: 305-4v
Sanjay
Aug 12, 2015 03:41 PM
