Weak spark
Weak spark
ive changed all sensors new distributor plugs wires thermostat coil fuel filter . Weak spark i dont know what to try bext ive got a new ecm coming any ideas?? 907-347-2528. Im about ready to fly somebody up here who knows about this problem,,
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: Weak spark
If you have already changed everything that produces the spark then the only thing left is the voltage that drives it. Make sure your alternator is good and battery is good. Also check your grounds.
Other than that
What kind of car do you have?
What engine?
What year?
What is the cars history?
How do you know you have a weak spark?
Other than that
What engine?
What year?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
