Intake manifold torque setting?
Old Jan 7, 2002 | 05:54 PM
BlazinOR's Avatar
When I take the top end of my intake system apart to put in the new Accel injectors, want to retorque the intake manifold bolts - what is the torque setting for this?
Thanks in advance.
Old Jan 7, 2002 | 07:41 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Not a bad idea. I see those center bolts loosen up on SBCs all the time.
Go through all of them once at 25 ft-lbs and again at 45 ft-lbs with the same sequence.
Kind of like this, with 1 being the first bolt to torque and 12 the last one:
......................Right side...........................
front of........ 8 7 _ 9 10 _ 11 12........ back of
engine......... 2 1 _ 3 4 _ 5 6............ engine
......................Left side.............................
I have also seen the sequence as going in this order:
12 11 _ 4 1 _ 5 6
10 9 _ 3 2 _ 7 8
I always use the first sequence and it works perfectly - never warped a manifold and never had any problems with leaks.
Hope that helps.
Old Jan 8, 2002 | 09:45 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I go with the first one too.
Old Jan 8, 2002 | 09:52 AM
BlazinOR's Avatar
Thank you very much..............
ASE doc
Alternative Port EFI Intakes
Jan 12, 2020 11:35 AM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
theurge
Aug 21, 2015 12:46 PM
Jake_92RS
Aug 11, 2015 10:39 AM
