EGR valve compatibility
Old Nov 8, 2018 | 02:59 PM
rt66er's Avatar
Car: 1990 Pontiac Firebird Formula
Engine: L31 350 TPI
Transmission: Tremec TKX
Axle/Gears: 3.23 Posi
Converting my LO3 5.0 TBI to TPI. I have TPI hardware from 89 TPI 5.0. I know the 89 still used the heat sensor, but my 90 will not (using 1990 speed density PROM in 7730 ECM). Question is: can I use the 1989 EGR valve or is there some other difference between the 89 and 90 EGR valve other than the wire?
Old Nov 8, 2018 | 03:13 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: EGR valve compatibility
I think they are the same other than the temp sensor.
just verify if it’s a positive or negative back pressure valve. There will be a p or n on the valve body.
Old Nov 8, 2018 | 04:51 PM
rt66er's Avatar
Engine: L31 350 TPI
Thanks, the 89 EGR has an "N" on it. Will that work properly with the '90? I've read contradicting specs. Some call for P for 1990 LB9, some say N.
Old Nov 8, 2018 | 05:27 PM
Engine: Lb9
Transmission: M20
Old Nov 8, 2018 | 06:04 PM
Engine: Lb9
Transmission: M20
I think I would be inclined to try the n egr valve
https://www.gm-trucks.com/forums/top...neg-egr-valve/
Old Nov 8, 2018 | 09:19 PM
rt66er's Avatar
Engine: L31 350 TPI
Thanks, Brian.
88TransAmFreak
Jun 2, 2009 09:34 PM
z28onTweenkies
Dec 23, 2006 04:31 AM
CamaroManBlack
Apr 23, 2005 03:41 PM
Biochem
May 22, 2001 09:30 AM
