Correct TPI Intake Manifold Gaskets?
Old Nov 11, 2018 | 12:00 PM
rt66er's Avatar
Car: 1990 Pontiac Firebird Formula
Engine: L31 350 TPI
Transmission: Tremec TKX
Axle/Gears: 3.23 Posi
I have searched and read till I'm blue in the face and I cannot determine what intake manifold gaskets are correct for 1989 TPI 5.0. Want to use Fel-Pro and purchased a 1204 set, but they have the center port blocked. Can anyone out there please tell me the correct Fel-Pro gaskets part number? Don't need the plenum gaskets; already have those. Just need the intake gaskets. Thanks.
Old Nov 11, 2018 | 12:18 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Correct TPI Intake Manifold Gaskets?
Ms903142 is what I would try
Old Nov 11, 2018 | 01:12 PM
rt66er's Avatar
Engine: L31 350 TPI
Thanks. For some reason, Amazon says not for my vehicle. They look correct, just needed some verification.
Old Nov 11, 2018 | 01:54 PM
Engine: Lb9
Transmission: M20
They are a standard older sbc gasket. I think I have used them in the past. It’s been so long I’m guessing here.
Old Nov 11, 2018 | 02:06 PM
Engine: Lb9
Transmission: M20
You could always get the locally and return them if they don’t match up.
https://m.autozone.com/external-engi...sket/69932_0_0
Old Nov 11, 2018 | 02:16 PM
Engine: Lb9
Transmission: M20
It shows to fit 85-86 camaro with a 305 base model I would guess carb
it doesn’t specify. I’m sure I have used older sbc gaskets for tpi.
https://www.jegs.com/i/Fel-Pro/375/MS90314-2/10002/-1
this fits 85-92 tpi so I would assume the base gaskets are the same.
https://www.jegs.com/i/Fel-Pro/375/MS93035-1/10002/-1
the 1204 should have a removable piece for the egr passage center port.
the port size would be larger the only advantage would be if you port the intake and heads.
jtsk
Jul 16, 2010 10:16 PM
83ho86tpi
Jul 11, 2005 09:46 PM
MakeitQuick92RS
Jan 17, 2005 09:52 PM
88305tpiT/A
Jun 28, 2001 07:18 AM
