305 tpi Bad miss at idle
Old Dec 31, 2018 | 10:06 PM
larry86's Avatar
Car: 86 camaro iroc z
Engine: 305 tpi
I a 86 camaro 305 tpi. Has a bad miss at idle.doesnt seem to be miss when I'm driving
Old Dec 31, 2018 | 11:20 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 305 tpi Bad miss at idle
Have you tried to unplug injector plugs and or spark plug wires while running?
This would narrow it down to a cylinder.
Old Jan 2, 2019 | 03:56 PM
larry86's Avatar
Engine: 305 tpi
ok I'll try that. Thanks
Old Jan 2, 2019 | 04:22 PM
Galaxie500XL's Avatar
Car: 1988 IROC-Z
Transmission: T56 swap ongoing
Axle/Gears: 2.77 9-bolt Posi
If that doesn't get you anywhere, a compression test, coupled with hooking up a vacuum gauge would be a good next step. A burned valve often manifests itself as a miss at idle that becomes less noticeable once underway.
Old Jan 2, 2019 | 04:39 PM
larry86's Avatar
Engine: 305 tpi
ok would the throttle body have anything to do with it.
Old Jan 2, 2019 | 04:53 PM
Engine: Lb9
Transmission: M20
The Throttlebodys job is to maintain idle with its iac valve and to control engine speed with its butterflies and ecm feedback with tps. It would not cause a miss fire.
newagereject
Jul 21, 2012 04:50 PM
rv1890
Jan 14, 2007 01:24 PM
BOSS 357
Aug 23, 2006 03:06 PM
350turbo411
Apr 5, 2002 08:53 PM
