INTERESTING plug wire problem..miss..miss
Old Apr 1, 2002 | 01:18 PM
350turbo411's Avatar
Car: 1983 Z28 Clone
Transmission: TH350
NEW PLUG WIRES....car is running rough.. and it wont go ...in gear.......the car is missing ..right...right..
pulled the plugs...PERFECT..........LIGHT LIGHT BROWN..DRY AS HECK.....SO I'M delighted....now...the interesting part
i pull wire by wire ..from the distributor..with car running.....yes..I got zapped ....but......my number 1 and 8 cylinders are having some problems
when i pull the boot off of the dist....and let it arch ..about an inch......the car runs nice and smooth...as soon as i put the boot back on the dis......the clyinder dies......again..to number 8..i hold the spark plug boot about 1 inch..from the electrode.. the car smooths out.....put the boot back on ..and missfire..
soo right now i have 1 and 8 missfiring... plugs are good....i'm at a total loss..............................
any ideas??????it seems that ..the closer i put the boot to the electrode.....the worse it runs..???WTF......i've never heard of anything like this before in my life...................
Rob
Old Apr 1, 2002 | 01:31 PM
PLANT PROTECTION's Avatar
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
I would try swapping a wire from a cylinder that doesn't do it.
Old Apr 1, 2002 | 01:32 PM
Car: 1983 Z28 Clone
Transmission: TH350
ill try that ...sorry ..seems like the first thing to do ..but ..my headers are hot.. just wanted to see if anyone else has seen this.......defanately weird
thanx....now that you brought it up...i'm gonna go swich em now ..
Old Apr 1, 2002 | 01:59 PM
skunk's Avatar
RE:INTERESTING plug wire problem..miss..miss
Hi 350 Turbo411,
Sounds to me like the distributor cap has a small hairline crack in it, you might not even be able to see it at first, but I reckon that is whats up.
Open it up and look for the tell tale signs of arcing.
Remember electricity is like an apprentice!
If there is a short cut, it will find it .
Good luck.......
Old Apr 1, 2002 | 02:38 PM
Car: 1983 Z28 Clone
Transmission: TH350
ok.. i'm going to do that ...because ..i just changed with a new plug and a new wire ...same thing .......
i quickly scanned it for ..catostrophic failure.. i will look closer...
i've noticed the last time i had the cap off ..that ....the electrode on the rotor ..was all carboned up....as well as the springy piece of metal that goes to the coil...................i just cleaned it off...and slapped it back on........................
thanx...
rob
Old Apr 4, 2002 | 07:55 PM
87LB9B4Z's Avatar
Car: See ID
Engine: See ID
Transmission: M39
So, have you fixed the problem?
Old Apr 5, 2002 | 08:53 PM
Car: 1983 Z28 Clone
Transmission: TH350
yep......must have had something to do with the cap..i noticed that the electrode on the cap was EXTREMELY loose.....the others were quite loose also.b.ut....new plugs .......and new cap did the trick.......................
rob...
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
Infested
May 22, 2018 11:56 PM
djmarch
Aug 19, 2015 12:07 PM
