Best place to get replacement vacuum block for the EGR solenoid?
Old Jan 3, 2019 | 09:20 PM
Big&BadGTA's Avatar
Engine: 5.7L L98 TPI
Transmission: 700r4 Automatic
Is that a service part? The twin port vacuum block? Thanks
Old Jan 6, 2019 | 04:35 AM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Axle/Gears: G80 3.23
Re: Best place to get replacement vacuum block for the EGR solenoid?
If you're talking about the solenoid on top of the canister, I'm pretty sure its built in with the canister and cant be separated. But the GM trucks use a similar solenoid with the same connector that is separate from the canister. You could just adapt to that one.
Old Jan 6, 2019 | 06:30 AM
Big&BadGTA's Avatar
No, not at the canister. This is the rubber block st the passenger side back corner of tpi intake manifold base.
Old Jan 6, 2019 | 11:40 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
It has been discontinued. You will need to source a used one.
Old Jan 6, 2019 | 11:43 AM
Engine: Lb9
Transmission: M20
Old Apr 14, 2019 | 10:11 AM
Big&BadGTA's Avatar
Yes, that's the part.
djmarch
May 15, 2015 04:22 PM
1roc89z28
Sep 25, 2011 07:17 PM
88TransAmFreak
Jun 2, 2009 09:34 PM
anthony714
Jul 22, 2007 09:31 PM
86TpiTransAm
Nov 27, 2001 07:18 PM
