EGR ?
Old Mar 10, 2019 | 07:29 AM
BigBlock73's Avatar
Car: 90 IROC original owner
Engine: 5.7
EGR ?
On my 90 5.7
Many years ago I had the ZZ3/Corvette heads and Accel intake installed.
Custom chip as well.
Since the ZZ3 heads don't have the exhaust cross over port on them is EGR disabled?
Reinstalling the intake after repairing some issues and curious if I need to put it back on.
Old Mar 10, 2019 | 12:57 PM
SirReveller's Avatar
Car: '89 'ROC
Engine: 5.7L
Re: EGR ?
99% your chip deleted EGR (although I have read a few posts where guys claimed they deleted EGR and didn’t tune for it and no SES occurred)
I believe “putting it back on” in the context of your 113s would require some extra work as per the pics in post #13.
https://www.thirdgen.org/forums/tpi/...tte-heads.html
Old Mar 10, 2019 | 03:56 PM
BigBlock73's Avatar
Engine: 5.7
Re: EGR ?
Thank you Sir
Read through the link.
Not going to do all the modifications needed to get it working.
Thinking of getting a block off plate.Anyone have one For Sale?
What else is associated with the EGR that can be removed?
Old Mar 10, 2019 | 03:59 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: EGR ?
The tune has two things that need to be addressed. Code 32 flag. And the mat temperature which the egr is commanded on needs to be maxed out.
hawks has a block off kit or you can source one on eBay.
https://www.ebay.com/itm/SR-EGR-Bloc...wAAOSwBGBb20kN
Old Mar 10, 2019 | 04:19 PM
Car: '89 'ROC
Engine: 5.7L
Re: EGR ?
Or one with a “cool” TPiS logo...that you’ll never see :P
https://www.tpis.com/parts/view/12
...are you sure your accel base doesn’t already have a block off plate in it? I would bet any pro shop competent enough to tune the EGR out wouldn’t skip that.
Old Mar 10, 2019 | 04:41 PM
BigBlock73's Avatar
Engine: 5.7
Re: EGR ?
Tuned
I purchased that one off ebay.
The heads and intake were swapped in 1994 and the car had to pass the emissions standards of the day.
I just removed the EGR valve to clean the intake.
Assuming they left everything else looking as if it was working.
Old Mar 10, 2019 | 04:47 PM
Engine: Lb9
Transmission: M20
Re: EGR ?
If the egr solenoid has just been removed and you get a error 32 you will need to have another tune done.The ecm doesn’t see nox it sees the solenoid resistance.
Old Mar 10, 2019 | 05:33 PM
BigBlock73's Avatar
Engine: 5.7
Re: EGR ?
The EGR system wont show a code even if there is no exhaust?
Will reinstall everything if it's going to show an error code.
Old Mar 12, 2019 | 06:18 AM
BigBlock73's Avatar
Engine: 5.7
Re: EGR ?
I put all the EGR stuff back on.
Don't want to make any changes until I get it running well again.
Old Mar 17, 2019 | 01:49 PM
BigBlock73's Avatar
Engine: 5.7
Re: EGR ?
Reassembled as I found it.
Running very well
Thanks for all the help
Slow89Iroc-Z
Jul 5, 2002 01:40 AM
Slackett
Jun 11, 2002 05:28 PM
TPICherokee
Feb 24, 2001 03:36 PM
JPrevost
Dec 2, 2000 06:58 AM
