Need some clarification here..
Car: 87 IrocZ.
Hey guys..ive done a few searches on this but just needed a solid answer as far as deleting the stock oil cooler. Car is a bone stock 87 Iroc 5.0 TPI. Just to clarify, to delete i just undo the cooling lines..pull of the filter..the unscrew the cooler off the block?...question is..when i take it all off..can I then just screw on a new filter back onto the block or do i need to take/use anything off of the cooler to mount the filter? I understand i need to change the bolts to the adapter because the bolts currently in it are longer to keep the cooler from spinning..what size bolt do i need to use to replace them with? just want to run the straight filter but need to know if theres any adapters i need or is it the traditional oil filter thread under all that crap?
second question..ive been getting mixed info on the numbers..but is there a specific filter number for running the "long" filter instead of the stock shorty since i wont be running a cooler and ground clearance shouldnt be an issue? Preferably a wix/napa filter.
Car: 1985 Z28
Engine: 305 LG4
Re: Need some clarification here..
Been a while since I looked at the one on my wife's 1987, but I seem to recall it looked like you could just remove the cooler housing from the block and the filter screws right in like normal. I use a fairly large Mobil 1 filter m1-302a, which I think crosses to a wix 51060.
Car: 1985 Z28
Engine: 305 LG4
Here is another post in the cooling forum that might help you.
https://www.thirdgen.org/forums/cool...il-cooler.html
Car: 87 IrocZ.
Thanks guys..got it all done and wow..gained about 20lbs oil pressure..that old piece of junk apparently was clogged. Put on a wix long filter and replaced the oil pressure switch (which was leaking). Just had to change the bolts that held it in place. Good to go!
TraviZ
Oct 2, 2007 07:15 PM
