What happens when you max out the stock mass
Old Apr 12, 2019 | 12:05 PM
bensbaby's Avatar
Car: 1988 GTA Trans am 1 owner since new
Engine: 383 built
Transmission: 1995 camaro t56 6 speed
Axle/Gears: 3.24 posi 9 bolt
88 gta tpi
What hp does the mass max out at and when th is happens what does it do when your going wot
And is there anyone who has any way to convert it
To something better
Old Apr 12, 2019 | 12:17 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: What happens when you max out the stock mass
Closer to 300 whp give or take depending on rpm
Most heads cam intake swap cars will get close if not exceed the program limit
doesnt mean anything bad really, just means the maf is no longer capable of fueling the motor above the 255 g/s limit or whatever. It will still take in more air but the fueling now has to come from enrichment tables vs rpm and open loop enrichments.
easy to work around
edit: if you mean how much can be made thru the 3” maf housing, it would be over 400 whp. It becomes a restriction the higher you go just the air velocity increases alot more. A 3.5” on my 400 whp 383 did not gain anything that i could see at the track
Old Apr 12, 2019 | 01:36 PM
GeneralDisorder's Avatar
I just got rid of the problematic MAF system by installing the EBL Flash-II from Dynamic EFI.
Besides the tuning difficulties and dangers inherent in the stock MAF limitations - quality replacement MAF's are expensive and getting harder to find. For the cost of a decent MAF you are almost at the cost of going to the EBL system which runs off $10 MAP and IAT sensors that are in stock at every corner parts store.
GD
jnz28z
Aug 13, 2005 11:14 AM
redbird_400
Mar 18, 2002 11:48 PM
Josh 91RS
Feb 19, 2001 10:46 PM
