Ford fuel injectors????
Old Jan 9, 2002 | 08:46 PM
88greyiroc's Avatar
i bought some fuel injectors off the net they are brand new the guy said they were for a 350 tpi camaro so i bought them. Upon closer examination the fuel injectors have ford written on them.Are these gonna fit into my car?
Old Jan 9, 2002 | 11:10 PM
Yelofvr's Avatar
I use the Ford motorsport 24lb/hr injectors in my engine with no problem whatsoever, many people use these injectors with good results.
Old Jan 9, 2002 | 11:17 PM
poncho9789's Avatar
what color are the injectors if they are
orange=19#
blue =24#
red =30#
brown =38#
hope you got the kind you wanted.
Old Jan 10, 2002 | 08:05 AM
88greyiroc's Avatar
mine are yellow and brown.
88greyiroc's Avatar
the top is yellow i am at school and i can't really remember what color the bottom is i am pretty sure its brown.
Old Jan 10, 2002 | 11:26 AM
poncho9789's Avatar
I have never heard of a yellow and brown ford injector my accell injectors are yellow and brown but... you never know
Old Jan 10, 2002 | 01:41 PM
JR4444's Avatar
mine are yellow and brown too. I think I bought from the same guy you did.....the injectors work great.
Old Jan 10, 2002 | 03:04 PM
88greyiroc's Avatar
ok mine have a blue seal on the yellow part the connector is on the yellow part the lower half is black with a black seal and a little brown bottom. i wish i knew what lbs/hour they were i am running them in my 350tpi and it has about 300 flywheel hose power so i am hopin they are 24 lbs/hr.let me know if you know what size they are the ford is wrote in little letters on the yellow part.
Old Jan 10, 2002 | 10:28 PM
88TAJeff's Avatar
Car: 88 T/A
Did you buy those from Fiveomotorsport in California? I've been considering those, want to know if you like them, and if they're in good shape.
Old Jan 10, 2002 | 10:49 PM
rezinn's Avatar
I have blue ford injectors.. but I had thought they were 19#...
Old Jan 11, 2002 | 05:00 AM
poncho9789's Avatar
If you look at a stock mustang 5.0 they will have a orange injector they are the 19# injectors. The larger truck engines 5.8s have blue top 24# injectors. Greay88iroc you probably have accell injectors that is exactly what my injectors looked like. Rezinn congrats you have 24# injectors. Just to let you guys know ford injectors don't have ford written on them. they only have codes printed on tht flat part on the side were the injector connector goes. There is a code in the same place on the accell in jectors but there is also a poundage on the injector on the surface purpendicular and bellow the injector code that the.
Old Jan 11, 2002 | 07:58 AM
88greyiroc's Avatar
ok poncho why would it say FORD if it was made by accell.that is dumb.if that was the case for could so kill them and i would go after fiveomotorsports for selling them to me.
Old Jan 11, 2002 | 01:28 PM
88greyiroc's Avatar
doesn't anyone know what size mine are?
Old Jan 13, 2002 | 09:49 AM
poncho9789's Avatar
I am not saying that they are not ford I am saying I have never heard of a yellow top injector. Also why don't you call or go to a ford dealership and ask a mechanic. Some times it pays to do your own homework.
Did you ever think you might should have asked what injectors you were buying before you bought them??? That would have saved you a whole lot of trouble. You might have a newer injector that won't work on your car. I have never seen a set of ford injectors that say ford on them.
If you want to get pissed and call people dumb (who bought injectors that didn't know what they were) you might be up the proverbal creek later.
Old Feb 17, 2002 | 04:01 PM
88greyiroc's Avatar
I FORGOT I HAD THIS BUT TO CLEAR IT UP FORD DOES WRITE ON THERES AND THEY ARE 19 POUND INJECTORS OUT OF A 4.6 MUSTANG
Old Feb 17, 2002 | 04:46 PM
Guest
Guest
Posts: n/a
I concur. I have a set of 30's, each one has the Ford script logo with oval right on the side. So did the 19's I had. Ford likes to put their label on all their parts. They are especially good about nailing every single piece with Ford or FoMoCo on Mustang and T-bird parts, from what me and my friends observed over the years of working on them.
bryan623
Mar 22, 2021 06:43 PM
New2Chevy
Oct 4, 2015 11:27 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
